Activity › Forums › Creative Community Conversations › SD DVD encoding
SD DVD encoding
Posted by Steve Cornell on June 14, 2011 at 4:01 pmCan anybody tell me why the burning software such as iDVD, Toast 10..etc is not using the ENTIRE space available when burning a SD DVD ?
The file size for my video is 527MB, 1920×1080 with a bit rate of 26 mbits/sec. The video is 2.5 minutes in duration.
There’s plenty of room on the disc so why is Toast and or iDVD ruining the quality of my clip and not utilizing the entire 4.7GB of available space?
I’ve tried ‘best quality’, pro quality and high quality. They are all terrible and are using less than half the disc space available.
What is happening with the asset encoding process ?
Walter Soyka replied 15 years, 3 months ago 4 Members · 5 Replies -
Stephen Smith
June 15, 2011 at 2:30 pmI’ve never used iDVD or Toast to make a DVD Video disc so I’m sure I’m not the best person to talk to. But, 527MB for a 2 minute HD video sounds super small. What codec are you using to edit with? Did you compress your own mpeg2 files.
Stephen Smith
Utah Video ProductionsCheck out my Motion Training DVD
Check out my Motion Tutorials
Brian Mulligan
June 16, 2011 at 2:22 amSD DVD’s are encoded with the mpeg2 format. The video is 720×480. It can be 4×3 or 16×9 (annamorphic). The bit rate is about 9 mb/sec.
SD DVD’s as video is also measured in time not file size. You can get about 60 mins of 720×480 video on a 4.3Gig DVD.
You will never get a 2.5 min video to “FILL” the entire disc. Some programs might allow you to raise the bit rate of the mpeg encode, but it more than likely won’t play in a standard DVD player.
Walter Soyka
June 16, 2011 at 2:42 pm[Brian Mulligan] “SD DVD’s are encoded with the mpeg2 format. The video is 720×480. It can be 4×3 or 16×9 (annamorphic). The bit rate is about 9 mb/sec. You will never get a 2.5 min video to “FILL” the entire disc. Some programs might allow you to raise the bit rate of the mpeg encode, but it more than likely won’t play in a standard DVD player.”
I’d only add that the MAXIMUM bit rate is about 9 Mb/s. This is the fastest that a DVD player is expected to read data from disc. You can go lower to fit more content on the disc (sacrificing quality), but if you go higher than about 9 Mb/s, it will be out of spec and may not play on a standard DVD player.
[Steve Cornell] “The file size for my video is 527MB, 1920×1080 with a bit rate of 26 mbits/sec. The video is 2.5 minutes in duration.”
How are you preparing this HD file for an SD DVD?
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Steve Cornell
June 16, 2011 at 2:55 pmExport PROREs from FCP. Open that file in QT and export for QT movie using the highest settings I can get. 80,000 kbit/sec H.264 multi-pass// key frame every 24 even though its 30P footage.
I then import this beautiful and clean footage into iDVD and letting the asset encoder destroy the quality.
I’ve also tried a 1280×720 version that looks a “little” bit cleaner after burning onto a SD DVD but again nothing like the original.
Walter Soyka
June 16, 2011 at 3:20 pm[Steve Cornell] “Export PROREs from FCP. Open that file in QT and export for QT movie using the highest settings I can get. 80,000 kbit/sec H.264 multi-pass// key frame every 24 even though its 30P footage. I then import this beautiful and clean footage into iDVD and letting the asset encoder destroy the quality.”
No need for the intermediate H.264 encode. You could bring the ProRes file directly into iDVD and then let the asset encoder destroy the quality. You’d save a lot of time and might get a bit of an increase in quality.
You could also use Compressor and Toast or DVD Studio Pro instead. You’ll have a lot more control over the encode in Compressor.
Personally, I think that Innobits BitVice SD is the best SD MPEG-2 encoder available for the Mac. I used it all the time for DVDs.
Walter Soyka
