SD CARDS AND HDTV’s
This may not be the right forum – but I’m now getting desperate and crazy…
For the last few days I’ve been banging my head very hard on the wall. I suddenly had the idea that if memory cards could write data in camera – then be used for capture on to computer, they maybe they could also deliver data to an HDTV. I know you’re supposed to be able to take a card from a camera with AVCHD files and push them out through a tv – but what if you wanted to edit a program and then put a plasma in a Mall without a blu ray DVD player and just use the card slot in a tv like a plasma viera 42 inch ? This becomes important if you have several plasmas to feed and want to cut cost down.
So I just coded, transcoded, put out blue ray images – all kinds of stuff. Nothing worked. The card reader in the tv says mpeg 2 or acvhd – I bought various bits of software – unfortunately the only card reader I have is a little digital camera and so it worries me that the file structure on something like this may not be good for movie playbak – also, if the tv is 1920 x 1080 – should the files be that and if so at what level should the card be ? Is SDHC fast enough to deliver the data.
Has anyone done this – is an Mpeg 2 or AVCHD file from a camera markedly different from that generated on a pc or mac ???
A long term DP – likes 35mm and HD equally – changing with digital media – Began as a commercials editor !
