Activity Forums DSLR Video sd card emergency-canon 60d
  • sd card emergency-canon 60d
    Posted by Yotam Monk on June 17, 2012 at 12:57 am
    a very strange sceanrio…
    i shoot 6 clips yesterday with my canon 60d
    5 of them r perfectly good,but one is making me a lot of problems
    i cant copy it to my computer,i have tried many things like convert,trim in the camera,capture the screen while playbacking.. but i keep on failing
    by the way english is not native to me…
    any new idea on how to get the clip out of the sd card?
    the sd card is sandisk extreme 45mbs class 10
    the camera is canon 60d
    all the best guys
    thank you
    yotam
    Chris Wright replied 14 years, 3 months ago 3 Members · 3 Replies
  • Steve Crow
    June 17, 2012 at 2:45 am
    What happens when you try and copy the mov file over to your computer? Does your computer “see” the file or just the other ones that copied over okay?
    If the camera can see and play the file back then you might try using the software that came with the camera that is normally intended to allow you to control the camera from the computer. If this software allows you to play back the clip then you should be able to screen capture it
    You said you tried screen capturing but it didn’t work, why not? What happened?
    Steve Crow
    Crow Digital Media
    http://www.CrowDigitalMedia.com
  • Yotam Monk
    June 17, 2012 at 7:55 am
    what ever apllication im working with it stopps working after transfering 200 mb from the file
    i spoke to a friend that says that the problem is that the file hasnt been finelized properly.
    screen capture allso aborted at the same point in the clip
    and the canon software as well..
  • Chris Wright
    June 18, 2012 at 11:16 am
    Easeus Data Recovery Wizard can recover flash cards and we use it at work.
