Activity › Forums › Apple Final Cut Pro Legacy › SD Beta-to-PAL ProRes…?? how?
  • SD Beta-to-PAL ProRes…?? how?
    Posted by Stu Aull on August 25, 2011 at 9:02 pm
    Hi All
    Russian client wants to go home from shoot with ProRes PAL files of our BetaSP NTSC-SD shoot.
    presume Compressor is the way to go, but unsure of steps to take:
    1) drop SD clip(s) into Compressor
    2)convert to SD 8-bit Uncompressed PAL
    3)convert THIS to Pro Res?
    I don’t seem to be seeing a direct “ProRes” PAL option in Compressor.
    Specs:
    FCP 7.0.3
    Compressor 3.5.3
    Betacam 8-bit Uncompressed
    thanks!
    Stu Aull
    Alaska
    Stu Aull replied 15 years, 1 month ago 3 Members · 5 Replies
  • Rafael Amador
    August 25, 2011 at 9:29 pm
    [stu aull] “1) drop SD clip(s) into Compressor
    3)convert THIS to Pro Res?”
    Why to go 8bUnc?
    Capture Prores NTSC, convert to Prores PAL in Compressor.
    [stu aull] “I don’t seem to be seeing a direct “ProRes” PAL option in Compressor”
    Good oportuniy o do it your self and learn something new.
    720×576 CCIR-PAL pixels,25fps,Inelaced Upper first.
    rafal
    http://www.nagavideo.com
  • Michael Gissing
    August 25, 2011 at 11:25 pm
    And search this forum for advice on best settings for frame controls in Compressor as the topic of standards conversion by software has been often discussed here.
  • Stu Aull
    August 26, 2011 at 7:45 am
    so – I WILL check thru the archives then!
    At least I now know it is POSSIBLE to make the conversion in Compressor.
    Can anyone comment on the _quality_ of the conversion vs say Natress Conversion software? Which I hear is very good…
    now to start digging…
    Stu Aull
    Alaska
  • Rafael Amador
    August 26, 2011 at 8:43 pm
    Both should do it the similar.
    Going NTSC to PAL is about re-scaling (720×480 to 720×576) and droppind some frames (30 to 25).
    Compressor should be better doing the re-scaling (Frame Control ON, Scaling: BEST)
    Dropping frames shoud be the same in both applications; BUT to get Compressor do his job, you need to set “Retiming: Lineal”.
    That’s the option that will degrade your footage the less.
    Don´t set “Frame Blending”: No Frames to blend. Waist time.
    Don´t set Optic Flow: You will end up with a fully processed synthetic picture.
    Your best advicer is a short test (some picture with movement) with the different options.
    rafael
  • Stu Aull
    August 27, 2011 at 4:39 am
    Thanks Rafael-
    actually precious LITTLE specific detail in Archives that I could find!
    certainly nothing close to a “step-by-step”!!
    your info has been the most complete so far – thank you
    Stu Aull
    Alaska
