Activity › Forums › Apple Final Cut Pro Legacy › SD and HD out at the same time.
  • SD and HD out at the same time.
    Posted by Olof Ekbergh on March 10, 2009 at 12:59 pm
    I have AJA Kona LHe setup from Media100.
    In Media 100 I can output different signals through SDI 1, 2 and component/YC/composite outputs at the same time.
    This is great I can view HD on one monitor from SDI and use SD scopes from component out.
    Or record SD and HD to tape at the same time.
    I cant figure out how to do this in FCP even if I set up using AJA control panel. It is either HD on all 3 outs or SD.
    Olof Ekbergh
    Walter Biscardi replied 17 years, 6 months ago 5 Members · 8 Replies
  • 8 Replies
  • Walter Biscardi
    March 10, 2009 at 1:03 pm
    AJA Control Panel.
    Format Tab – Set your Primary and Secondary Formats correctly for what you’re working with.
    Click each Output from the Kona.
    Select whether you want the Primary or Secondary Format to display on each output.
    With the Control panel you can do all three outputs independently. SD, HD and even cross-conversion.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Olof Ekbergh
    March 10, 2009 at 1:12 pm
    Where is that format tab?
    AV setup does not have that tab FCP 6.0.5, it only has 1 out.
    Olof Ekbergh
  • Ken Harper
    March 10, 2009 at 1:26 pm
    On my system the AJA box controls the outputs. I have 2 SDI outs that can be set seperately. Check you output device.
    Ken Harper
    Sr. Editor/Director of Technical Operations
    Moving Pictures, Inc.
  • Steve Eisen
    March 10, 2009 at 1:27 pm
    This should help you out.
    https://www.aja.com/pdf/support/AJA_KonaLH_manual.pdf
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Walter Biscardi
    [olof ekbergh] “Where is that format tab?
    AV setup does not have that tab FCP 6.0.5, it only has 1 out.”
    As I stated at the beginning of my response. AJA Control Panel.
    Read my Blog!
  • Olof Ekbergh
    March 10, 2009 at 1:41 pm
    Well in my Sys prefs there is a M100 control panel, not AJA’s own.
    I can set SDI 1,2 and analog outputs.
    But it makes no difference, if FCP is set to HD they all turn HD, or SD all SD.
    I guess I will have to contact M100.
    Olof Ekbergh
  • Chris Poisson
    March 10, 2009 at 4:00 pm
    M100 is not going to be able to help you with an FCP issue. As Walter said, there is an AJA control panel, it is a little app, located in your applications folder.
    Have a wonderful day.
  • Walter Biscardi
    March 10, 2009 at 8:23 pm
    [olof ekbergh] “Well in my Sys prefs there is a M100 control panel, not AJA’s own. “
    It’s not in your System Preferences.
    Once again. The AJA Control Panel. it’s in your Applications Folder.
    [olof ekbergh] “But it makes no difference, if FCP is set to HD they all turn HD, or SD all SD. “
    Yes, this is absolutely correct because you don’t change anything in FCP, you change in the….. AJA Control Panel.
    Read my Blog!
