Activity › Forums › Apple Final Cut Pro Legacy › SD and HD footage – exporting 16 x 9
  • SD and HD footage – exporting 16 x 9
    Posted by Jonathan Wald on June 25, 2010 at 3:05 am
    I am editing a film containing standard SD Pal footage and 1280×720 HD footage. I ultimately want to export 16×9.
    Around 80% of my footage is SD, so I started cutting in an SD timeline and letterboxing the SD footage, but I realised this may not be the best approach, since I don’t know how I would then get my film out as 16:9 rather than letterboxed.
    Can anyone suggest the best workflow for me to follow? Ideally I wouldn’t have to re-edit what I’ve already done.
    Jonathan Wald replied 16 years, 3 months ago 3 Members · 9 Replies
  • 9 Replies
  • Michael Sacci
    June 25, 2010 at 4:18 am
    Can be simple if you have not used the motion tab on a lot of clips.
    Duplicate your sequence and go to settings and check anamorphic. Open this timeline. The footage will now look stretched and letterbox. Select all the clips on the timeline, right click > Remove Attributes, then select Basic Motion and Distort, this will reset the clips and look correctly in the sequence.
  • Jonathan Wald
    June 25, 2010 at 4:53 am
    Hey thanks for the response.
    I tried what you suggested and even after removing attributes the footage is all stretched….
    My current (pre-duplication) sequences settings are 720×576, DV Pal aspect ratio and Pal pixel aspect ratio, in case that’s wrong or needs to be changed….
    Or is it meant to look stretched and I fix it on output?
  • Michael Sacci
    June 25, 2010 at 5:27 am
    I’m in NTSCland and that has worked for me.
    Once you reset the Basic Motion and the Distort settings it should fill the frame and look normal.
    Are your clips anamorphic to begin with?
  • Rafael Amador
    June 25, 2010 at 10:13 am
    Should works as Michael says.
    However you will need to resize the HD footage that now should be at 100%.
    rafael
    http://www.nagavideo.com
  • Jonathan Wald
    June 25, 2010 at 11:42 pm
    I’ve tried it a few times, and it’s definitely still stretched. It gets a bit better if I change the pixel aspect ratio to square or NTSC, but it doesn’t get right unfortunately….
  • Rafael Amador
    June 26, 2010 at 5:30 am
    Johnatan,
    Somewhere must be a miss match between the footage and the sequence.
    Open a new sequence a drop any clip to conform the sequence, then copy and paste the old sequence in the new one and proceed to “Remove attributes”.
    rafael
  • Jonathan Wald
    June 27, 2010 at 12:38 am
    That seemed to get me closer – but after I did it, I had to go through and manually zoom in on all the SD clips – is that what’s meant to happen?
  • Rafael Amador
    June 27, 2010 at 6:36 am
    If the sequence is HD, you will need to zoom in the SD clips.
    Is the sequence is SD, you will need to zoom out the HD clips.
    rafael
  • Jonathan Wald
    June 29, 2010 at 1:35 am
    Ok, thanks for that – I guess it’s working!
