Activity Forums Blackmagic Design sd 8bits blackmagic 422 makes hang after 7
  • sd 8bits blackmagic 422 makes hang after 7
    Posted by Oscar G. on April 19, 2006 at 1:31 pm
    Hi
    Every times we import into after 7 avi sd 8 bit blackmagic 422, after hangs…
    The problem does not exist with 10bit format.
    10 bits avi files or well recognize in after (10 bits 422 decklink…) but 8 bits 422 are “interpreted” has uncompressed rgb16(virtualdub) and 8bit yuv 422 in after effects…
    Any solution?
    Regards
    Well, well, well…
    Kristian Lam replied 20 years, 4 months ago 3 Members · 4 Replies
  • Kristian Lam
    April 20, 2006 at 7:11 am
    Hi Oscar,
    Kindly refer to this tech note:
    https://blackmagic-design.com/support/detail.asp?techID=151
    regards
    Kristian Lam
    Blackmagic Design
  • Oscar G.
    April 20, 2006 at 10:41 am
    Thanks for the reply.
    Waiting this patch!
    regards
    Well, well, well…
  • Ray K
    April 21, 2006 at 12:53 am
    hi all..
    Kristian after reading the release.. It says blackmagic is working with Adobe on a fix… As you know adobe is tightlipped… in fact there ppl i spoke with at a seminar deny the problem and refered me to talk to black magic ppl… so my question since both sides are working on it, is when can we expect some solution to this….
    regards
    ray
  • Kristian Lam
    April 21, 2006 at 2:08 am
    Hi Ray,
    Unfortunately, I do not have a date. I’m pretty sure it’s something Adobe has to fix, not us. I’ll post back if I hear anything.
    regards
    Kristian Lam
    Blackmagic Design
