Activity Forums Apple Final Cut Pro Legacy SD 4/3 letterbox to Sd 16/9 dvd
  • SD 4/3 letterbox to Sd 16/9 dvd
    Posted by Erik Cartoni on April 6, 2010 at 3:00 pm
    Hi I’m trying to figure out what is the best way of doing this odd conversion (SD 4/3 letterbox to Sd 16/9 dvd), I’m doing this because my client wants to have his footage displayed without letterbox and without stretching on new Lcd Tv’s, how can I do this with maximum quality possible?
    Roli Rivelino replied 16 years, 5 months ago 2 Members · 3 Replies
  • Roli Rivelino
    April 6, 2010 at 3:25 pm
    I would do this in compressor, go to compressor and choose create new setting, choose quicktime movie or MPEG 2 for dvd and then go to the geometry tab in the inspector window, then choose the 720 480 and then set to either NTSC CCir 601 or PAL CCir depending on your needs.
    aka Newbie Wan Kenewbie. “The young Newbie, is now a Padawon.”
    System
    Mac Pro 2.8Gb quad core
    8Gb RAM
    1x 320Gb 7200 hardrive
    1x 1Tb 7200 hardrive
    Nvidia Geforce 8800 512mb Graphics card
    1x 1Tb external WD ‘My Book’ eSata
    Equipment
    Panasonic AG-HVX 200
    Firestore FS-100
  • Erik Cartoni
    April 6, 2010 at 3:29 pm
    So, i crop the edges of letterbox in Compressor preview window, and then set 720×576 output (for me it’s pal size) and then export a squished image to be the anamorphisized in FCP?
  • Roli Rivelino
    April 6, 2010 at 3:42 pm
    No you wouldn’t use cropping, because you want to go from 4:3 to 16:9, so you need to scale your image up (and lose image quality), if you had a 16:9 letterbox image, then you could use cropping to get rid of the letterbox.
    So the way I described in the first instance would be the way to go, you don’t need to send it back to FCP from compressor, yes the image will be squished, but there’s not an awful lot you can do about that.
    System
    8Gb RAM
    Equipment
    Firestore FS-100
