Activity › Forums › Compression Techniques › SD 4/3 letterbox to Sd 16/9 dvd
  • SD 4/3 letterbox to Sd 16/9 dvd
    Posted by Erik Cartoni on April 4, 2010 at 11:41 pm
    Hi I’m trying to figure out what is the best way of doing this odd conversion (SD 4/3 letterbox to Sd 16/9 dvd), I’m doing this because my client wants to have his footage displayed without letterbox and without stretching on new Lcd Tv’s, but wants to have the maximum quality possible?
    Any good tip for compressor? what should be the workflow?
    Andrew Saliga replied 16 years, 5 months ago 2 Members · 3 Replies
  • Andrew Saliga
    April 8, 2010 at 8:11 pm
    Do you have access to the master file, the one that hopefully doesn’t have letterboxing?
    -Andrew Saliga
    Steelehouse Productions
    http://www.steelehouse.com (undergoing a much-needed redesign)
    http://www.vimeo.com/steelehouse
  • Erik Cartoni
    April 8, 2010 at 9:27 pm
    Yes but master file is letterbox!
  • Andrew Saliga
    April 8, 2010 at 10:03 pm
    What are the specs on this master file, particular codec/format?
    I’m thinking one encode (using ProRes) to perform the crop and another to perform the MPEG-2 compression. I guess you may be able to both at the same time. Give it a few test encodes with short snippets of video.
    -Andrew Saliga
