Activity Forums Maxon Cinema 4D Sculpting with hard edges – smoothing effect?
  • Sculpting with hard edges – smoothing effect?
    Posted by Jack Daniels on June 16, 2015 at 5:08 pm
    I haven’t used Cinema 4D in a while, but I’m trying to sculpt a barricade model I made real quick to give it some detail. When I subdivide, it causes the edges to smooth, but I would like to make them stay the same. Is that possible in sculpting? Or have I screwed myself?
    I’ll post an example.
    Again, I’m sorry because I’m not that great a sculpting, so please try if you can explain this to a beginner.
    Adam Trachtenberg replied 11 years, 3 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    June 16, 2015 at 8:52 pm
    Sculpting subdivision is just like Subdivision Surface modeling. You can prevent … or minimize at least … the smoothing by adding some edge loops close to the edges you want to be sharp. Or, since you’re going to have a high poly object anyway for sculpting, you could use the regular subdivide command before sculpting.
