Activity › Forums › Adobe Premiere Pro › Scrubbing frame by frame in timeline
Posted by Stephen N. on February 10, 2014 at 6:00 amHey all,
Switcher here from FCP7/X. How can one scrub frame by frame in the timeline without the mouse? In any other NLE all one needs to do is use the left or right arrows. In Premiere, when you do that nothing happens. This seems like something that is so simple. Does something need to be enabled prefs?
Kuhnen Brown replied 12 years, 7 months ago 4 Members · 5 Replies -
Shane Ross
February 10, 2014 at 7:01 amYOu need to make they keyboard layout match that of FCP. Under the Premiere Pro Menu, choose KEYBOARD SHORTCUTS. In there click on KEYBOARD LAYOUT PRESETS and choose FCP. Then the keyboard will mimic what you have in FCP.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Kuhnen Brown
February 10, 2014 at 9:37 amIf you have a Shuttle Pro (Contour Design) scrubbing is a breeze using the shuttle knob. Other buttons can also be customized.
Kuhnen -
Walter Soyka
February 10, 2014 at 4:56 pm[Stephen Nahroniak] “Switcher here from FCP7/X. How can one scrub frame by frame in the timeline without the mouse? In any other NLE all one needs to do is use the left or right arrows. In Premiere, when you do that nothing happens. This seems like something that is so simple. Does something need to be enabled prefs?”
Left and right arrow keys should do exactly this when the timeline panel is active, which is indicated as a gold outline. Click the timeline or hit Shift+3.
Arrow keys also work in the source monitor when that is active (Shift+2).
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Stephen N.
February 10, 2014 at 6:56 pmI tried all of the above and it doesn’t seem to respond.
The timecode will move when hitting left/right arrows but the actual timeline indicator stays still. It’s bizarre. I’m running CC. Is this a bug?
Kuhnen Brown
February 10, 2014 at 7:31 pmTry trashing the preferences (Shift+Option on boot-up).
KuhnenKuhnen Brown
InterMountain Digital
Oregon
