Activity Forums Apple Final Cut Pro Legacy scrubber not moving while sequence is playing
  • scrubber not moving while sequence is playing
    Posted by Suzin Daly on May 17, 2010 at 4:49 pm
    this is a new one for me, Just happened, the scrubber stopped moving while the the timeline is playing. When I hit the space bar it will jump to where I stopped it. the audio does not show levels nor the scrubber is moving along as it plays. Saved, closed project then reopened and still not moving. If I changed something to make this happen I haven’t a clue… any ideas on how to correct this
    Suzin Daly replied 14 years, 6 months ago 4 Members · 4 Replies
  • Tom Wolsky
    May 17, 2010 at 5:22 pm
    It’s called the playhead, not the scrubber. The timeline doesn’t move in FCP. You can either make the sequence fit to window or manually move the timeline while playing. I hate to do the latter because it distracts from viewing. The former is a pain if the sequence is long. Basically I just live with it.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • Terry Neilson
    May 17, 2010 at 11:02 pm
    FWIW– with the Magic Mouse while mouse pointer is in the timeline window a one finger swipe will scrub the timeline, two fingers jumps to the next edit point. If the pointer is in the Canvas one finger scrubs the playhead and two jumps to edits. And in the viewer one finger scrubs the viewer playhead and two fingers jumps to edit points in the timeline and opens the clip in the viewer.
    moving parts are so last year
    MAC Pro quad 2.66, 8GB, XFX 4870, 23″ ACD, 10.6.2, FCS3, MXO2 Mini, etc.
  • James Layton
    March 13, 2012 at 4:15 pm
    Did you ever solve this? I’ve just got the same problem. Was fine this morning and now it’s stopped…?
  • Suzin Daly
    March 14, 2012 at 12:49 am
    I didn’t solve the problem. What helped was to save, close FCP
    restart. Then went back in worked fine. It would be nice to know what creates the problem to begin with. It’s annoying…
