Activity Forums Apple Motion Scrolling/Movement Not Constant
  • Scrolling/Movement Not Constant
    Posted by John Locke on September 8, 2009 at 7:52 pm
    Whenever I try to scroll end credit text in Motion, regardless of the method (whether making the credits out of text or as an image or PDF)…and also when applying the Burns Effect to a large image, I’m getting inconsistent scrolling speed. It always starts slow, speeds up, then slows down again at the end. I’m not sure why this happening since there are only two keyframes… one with the item in the start position, and one at the end with item in the end position.
    I’ve messed around with settings, and found the one labeled “Constant Speed”… but that doesn’t seem to help.
    Any ideas on what I’m doing wrong?
    [Motion version 3.0.2]
    Stephen Smith replied 16 years, 11 months ago 2 Members · 3 Replies
