Activity Forums Apple Final Cut Pro Legacy scrolling titles
  • scrolling titles
    Posted by Brigitta Boccoli on February 20, 2008 at 1:32 am
    Having troubles with scrolling titles…
    like everybody I guess…
    Working with FCS2, in a 720p24 project in HDV.
    I must downcompress in mpeg2 for SD festival`s DVD copies,
    and I aspecting some flickering and motion problems in titles, but I noticed that I get the same
    problem when I export in native format.
    I tried Boris, Motion, Live Type, 1px blur, deflicker and so on…
    The credits are very long, so unfortunately I need scrolling text.
    Can anybody soggest me a pro-solution for scrolling titles?
    Otuside or inside FCS2.
    I mean… what does hollywood use for digital projects?
    They always look just fine.
    Bob Cole replied 18 years, 6 months ago 5 Members · 4 Replies
  • Aaron Williams
    February 20, 2008 at 3:35 am
    in the past, i’ve used after effects. it seems to do the job nicely. also, you need to make sure that they are not moving too fast, or they will strobe, just like footage will (it’s a product of the 24p framerate). the other thing i’ve tried is creating the titles in photoshop as one long image, then saving as an uncompressed format with an alpha (like targa) and keyframing that. it’s not the best solution, but it may solve your problem.
    Aaron Williams
    https://www.reaction-films.com
    https://www.roarnetwork.com
  • Sean Oneil
    February 20, 2008 at 9:17 am
    It’s a very difficult and annoying thing to do right. I use After Effects because it will tell you how many pixels per second it is scrolling. You gotta do the math and calculate it so that never lands in between any video lines. So for 720×480 NTSC, the titles need to scroll at 240 lines per second, 120, 60, etc. I’m not sure how you would deal with 24p footage. My brain isn’t working well enough right now to figure it out.
    Sean
  • Stephen Eckelberry
    February 24, 2008 at 11:30 pm
    Here is how I get to scrolling titles to look right:
    1. I make a seperate timeling just for the end titles. In the sequence settings I change the Aspect Ratio to HD 1440 (use something bigger if you like), Pixel aspect ratio to square and no field dominance, compression: animation
    2. I export the titles using QT conversion, image sequence, selecting TGA.
    3. I then import the TGA sequence into timeline I need it for, adjusting size and ratio as needed
    BTW to prepare titles properly before FCP, put your titles in a text file, changing to “make plain text”. then cut and paste that into your scrolling text. ALSO to have thing centered neatly, put an asterix in between the two sets of names or job description:
    Harrison Ford*Indiana Jones
    1st Asst. Camera*Joe Blow
    Stephen Eckelberry
  • Bob Cole
    March 7, 2008 at 5:06 pm
    [Stephen Eckelberry] “to have thing centered neatly, put an asterix in between the two sets of names or job description:”
    Very interesting post, but I’m not following it and would appreciate a more step-by-step explanation. How do you work with titles over a moving video background? How does the asterisk make the titles center? And, is there a way within FCP to adjust the scrolling title’s timing to avoid strobing/blurring, and to make the scroll ramp to a stop for a closing static title like the copyright notice?
    Bob C
    MacPro 2 x 3GHz dualcore; 10 GB 667MHz
    Kona LHe
    Sony HDV Z1
    Sony HDV M25U
    HD-Connect MI
    Betacam UVW1800
    DVCPro AJ-D650
