Activity › Forums › Adobe Premiere Pro › scrolling title
scrolling title
Posted by Gary Linzer on June 8, 2009 at 10:31 pmHi,I want to scroll the words of a song one line at a time over still images. In other words, one line would fade up then fade out as the other line fades in. I’m not sure how to do this. Any suggestions? Thanks, Gary
Lynda Caswell replied 17 years, 3 months ago 3 Members · 4 Replies -
Eddie Lotter
June 9, 2009 at 1:20 pmYou can use single-sided transitions to make titles fade in and out.
Cheers
Eddie -
Gary Linzer
June 9, 2009 at 4:25 pmHi, I’m not sure what you mean? Maybe I didn’t make myself clear. I have a title of about thirty lines. I want one line to fade up at the bottom of the picture and off as another line fades on. I’m not sure how I would do that with transitions. If I cut the title to put the transitions on, each section contains the whole thirty lines. As I said I’m probably not understanding what you mean. Thanks, Gary
Eddie Lotter
June 9, 2009 at 6:27 pmYou will need to use separate titles for each line.
I cannot think of a way to accomplish what you want to do with a single title in native PPro with any kind of ease.
Cheers
Eddie -
Lynda Caswell
June 15, 2009 at 3:25 amWhen I add the lyrics of a song to my moving stills, I make a title (using a template) for each “line” of lyrics. Then, just put them in another track and match them up to each image. I usually just let them fade in and out using the effect controls. Sometimes moving words can get in the way of the images or motions of the images. Hope this helps you.
Lynda C.
