Activity Forums Apple Final Cut Pro Legacy Scrolling Title issues
  • Scrolling Title issues
    Posted by Tom Amici on February 24, 2009 at 3:19 pm
    Hi All,
    I’ve tried both FCP & Boris scrolling titles in FCP and all I ever get are terrible results. Pulsing, bad aliasing is the best it ever looks. What’s the secret for perfect broadcast quality results in FCP?
    Regards,
    Matt
    Tom Amici replied 17 years, 6 months ago 3 Members · 3 Replies
  • David Hartnett
    February 24, 2009 at 3:42 pm
    In theory, you will achieve the best results by getting your graphics to move in full-pixel increments per frame, especially for vertical movement. This will require some maths 🙂
    For example, if you text box is changing its y-position by 300 pixels then you will want this change to happen over 300 frames. So your keyframes will need to be 300 frames apart (i.e. 10 seconds at 30fps) If that’s too quick, multiply the pixels by a whole number (2 or 3 might work), giving you 600 or 900 frames, so that it slows down by half or a third.
    I would also note that FCP-generated text also will look better on an interlaced external monitor than it will on your computer screen.
    Hopefully this will make a difference
  • Robert Due
    February 24, 2009 at 4:19 pm
    I have also had good luck doing the scroll in After Effects. I never had to do any “math”. Try rendering in frames or if that doesn’t look acceptable, render with fields to match your Sequence settings. Good luck.
    Robert Due
    Editor / Colorist
    INDEPENDENT EDIT
  • Tom Amici
    February 24, 2009 at 4:44 pm
    Thank for the good ideas.
