Activity › Forums › Adobe After Effects › Scrolling Text with Perspective?
  • Scrolling Text with Perspective?
    Posted by Ryan Foregger on June 15, 2011 at 5:53 am
    Hi all,
    I’m trying to create a scrolling text effect on the side of a building. The shape of the building is oblique and I can’t seem to get the perspective right.
    I’ve tried Precomping the text, using 3D orientation, and also corner-pin – no luck. The issue is that over time during the perspective drifts. What looks good at the top of the building, doesn’t work for the bottom of the building.
    Are there any tools I can use to achieve this effect? Am I missing something in the logic of what I’m trying to do? Any help would be great!
    Luis Cosme replied 15 years, 3 months ago 4 Members · 5 Replies
  • John Cuevas
    June 15, 2011 at 1:15 pm
    You can upload stills here. It might be easier for everyone to offer a solution if we had a better idea of the problem areas.
    Johnny Cuevas, Editor
  • Tudor “ted” jelescu
    June 15, 2011 at 9:17 pm
    you can also try a camera track (Camera Tracker- The Foundry, or Boujou or Syntheyes) and then position the text in 3d on the first frame- it would help if you precomp the text and have a solid in that precomp just for positioning (kinda’ like what Dave was saying).
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Ryan Foregger
    June 15, 2011 at 9:32 pm
    Thanks guys, I’ll upload a still.
    I had to turn something in this morning and what I ended up doing was rasterizing the text, changing the perspective in photoshop, dropping that into a precomp that was similar in size to wall of the building and doing the scroll in that precomp.
    Then I dropped that in the main comp and corner pinned it, adjusting as it went. Eventually the corner-pin got so skewed that it started clipping the pre-comp. I made it work (client approved), but wasn’t happy with the results.
    I’ll investigate your responses.
  • Ryan Foregger
    June 15, 2011 at 9:50 pm
    No, the shot is locked down. I’m using corner pin to get the text in line with the perspective of the building as it scrolls from bottom to top.
  • Luis Cosme
    June 15, 2011 at 10:37 pm
    put up a screen shot
