Activity Forums Apple Final Cut Pro Legacy Scrolling Text Problem
  • If you’re talking about the FCP Text generators, you should simply avoid using them.
    Instead use the text generators called “Title 3D and “Title Crawl” (from Boris), included on the install discs of FCP.
