Activity Forums Apple Motion Scrolling Text in Motion
  • Scrolling Text in Motion
    Posted by Gayle Gallagher on July 9, 2008 at 4:06 pm
    Hi. I am a NOVICE at Motion and it may be overkill for what I am trying to do.
    I am creating credits for a film and when I use the Scroll Text feature, the speed ramps up and ramps back down at the beginning and the end of the scroll. How do I turn this off so the speed of the scroll is consistent?
    Gayle
    Gayle Gallagher replied 18 years, 1 month ago 3 Members · 5 Replies
  • Noah Kadner
    July 9, 2008 at 8:52 pm
    [Gayle Gallagher] “Hi. I am a NOVICE at Motion and it may be overkill for what I am trying to do.
    Thanks!”
    Try a Throw behavior instead.
    Noah
    My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color and Win a Free Letus Extreme.
    Now featuring the Sony EX1 Guidebook, DVD Studio Pro and Sound for Film and TV.
    https://www.callboxlive.com
  • Jeremy Loftus-hills
    July 10, 2008 at 12:20 am
    In the keyframe editor change the properties of the motion gradient to ‘linear’.
  • Gayle Gallagher
    July 16, 2008 at 4:35 am
    Hi Jeremy,
    Pretend I am even more of a novice than that…
    Your advice sounds like it will work. I found that there is indeed a curve to the keypoints on my scrolling text…
    However, I don’t see where to change the properties to linear. (I am using Motion 2.0.1)
    Gayle
    July 16, 2008 at 10:15 am
    Hi Gayle
    Open your project.
    Under file item ‘Window’ check ‘Keyframe editor’.
    In the keyframe editor work out which of the graphs represents your scrolling text. (move the lines and it will become clear but be sure to edit undo after each move!)
    Hint: Since it has a variable speed the graph you are looking for will be ‘curvey’ (probably like an elongated S).
    Note it has a diamond shape at either end (the keyframes)
    Control click on this diamond shape at either the start or the end of the elongated ‘S’.
    Choose interpolataion/linear.
    The ‘S’ should change to a straight line.
    Scrolling should then move at a constant speed.
    Regards
    Jeremy
  • Gayle Gallagher
    July 16, 2008 at 11:03 pm
    Hi Jeremy!
    This is the part where I tell you how much you Rock!
    Thank you for the detailed help! That worked perfect!
    Gayle
    ps – the credits are for a film called “Shadowland” – here is the full-screen trailer:
    https://www.ShadowlandTheMovie.com/trailer1fs
