Activity Forums VEGAS Pro Scrolling text blurry
  • Scrolling text blurry
    Posted by Scott Francis on April 20, 2011 at 8:27 pm
    Hi All,
    I am doing titling for numerous nation spots, many of them also desire scrolling text. I currently use a generated text block, set a specific length of time, and then use key frames to have it move across the screen. Works pretty well, except my clients and I see the text is a bit blurry. I tried different fonts, adding and removing “reduce interlace flicker,” and there is still blurriness. I have also tried doubling the size of the text block (1440×960 instead of 720×480) and it seems better. But I still an a little concerned.
    What is the best way to do scrolling text (other than this) and how can I keep it from being blurry?
    I am using NTSC IMX 720×486 project settings(pulling in from Beta SP via Intensity Pro)
    Rendering to that preset and in “Best”
    I rendering to different formats depending on station requirements, but often use these
    NTSC 720×480 DV
    NTSC 720×480 MPEG 2
    NTSC 720×486 3M MOV
    The footage is 4:3 but with widescreen inside of it…Beta SP doesn’t do widescreen
    Thanks for all your input in advance!
    Regards
    Scott Francis
    Scott Francis
    Mind’s Eye Audio/Video Productions
    Mike Kujbida replied 15 years, 4 months ago 6 Members · 6 Replies
  • Daniel Hughes
    April 20, 2011 at 9:21 pm
    I believe you have already found it. By increasing the size of the text block thing you are increasing the resolution and sharpening the pixels. That’s why we have anamorphic lenses: they take a bigger, stretched picture that can then be squashed and scaled down with much better resolution.
    Daniel Hughes
    Amateur Writer, Director,
    Director of Photography
    United Kingdom
  • Danny Hays
    April 20, 2011 at 10:42 pm
    I would also try upping the bitrate of the files your rendering.
  • Douglas Spotted eagle
    April 20, 2011 at 11:18 pm
    you can also set the text block to double resolution and size accordingly. It’ll be sharper.
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Daniel Hughes
    April 21, 2011 at 11:22 pm
    I believe he already did that! I think that’s probably the only way though.
    Daniel Hughes
    United Kingdom
  • Linda O’connell
    May 5, 2011 at 12:13 pm
    I am having the same problem. Could you please be more specific in your recommendation? ..on setting the text block to double resolution?
  • Mike Kujbida
    May 5, 2011 at 8:48 pm
    Linda, change the numbers in the Frame Size box at the top left of Generated Media.
