Activity › Forums › VEGAS Pro › scrolling text
  • scrolling text
    Posted by Julieqs5100 on February 3, 2007 at 12:40 am
    HI there
    I’m trying to create scrolling text across the bottom of the screen to look like a breaking news story on a news ticker. Using the scrolling credit roll it stops in the middle, I don’t want it to stop, I just want it to go by, and repeat as long as I need it to.
    Julie
    Julieqs5100 replied 19 years, 8 months ago 2 Members · 2 Replies
  • Terry Esslinger
    February 3, 2007 at 1:21 am
    Place your text event on a track. Type a single line of type (your ‘ticker tape’) as long as you want – even if it disappears off the page. Using the placement tab place your text at the bottom but within the safe zone. Then place your curser over the text. It will turn into a hand. Move your text off the right side of the screen and set your first keyframe. Then move your entire text off the left side. The trick is keeping it at the same horizantal level. Then set the last key frame. When you play this your text will move from off the screen right, across the bottom and then off the screen left. If you stretch out the event it should repeat again and again depending on how long you stretch it out.
    Good luck
  • Julieqs5100
    February 3, 2007 at 1:38 am
    Holy Cow! Thank you so much for the very quick reponse, it worked and looks great….thanks again
    Julie
