Activity Forums Adobe After Effects Scrolling Numbers to 1 Billion
  • Scrolling Numbers to 1 Billion
    Posted by andy Jackson on January 26, 2021 at 5:05 pm
    I’m trying to create a number scroll from 0 – 1000000000 in ae21.
    Had a look around the numbers are limited to 30000.
    I’m not aware script enough to use those fixes … just wondered if any other ideas about how to do this? Only lasts for 24 frames ..
    Thanks in advance
    Walter Soyka replied 5 years, 7 months ago 2 Members · 1 Reply
  • Walter Soyka
    January 26, 2021 at 5:33 pm
    This is not going to be super-intuitive, but instead of the Numbers effect, you can use a Text layer, an Angle control (because sliders don’t go to 1 billion), and an expression.
    1. Add a text layer.
    2. Add an Angle Control effect to the text layer.
    3. Keyframe 0 and 1000000000 as you like on the Angle Control.
    4. Untwirl the text layer, then Alt+click the Text > Text Source stopwatch.
    5. Enter this expression:
    var numberAsText = "" + parseInt(effect("Angle Control")("Angle"));
    var separator = ",";
    numberAsText.replace(/\B(?=(\d{3})+(?!\d))/g, separator);
    The first line gets the value from the angle slider as an integer and changes it to text. The second line says we’ll use a comma as the separator, i.e. so you get 1,000 instead of 1000. (If you don’t want a separator, you can clear out the comma, leaving nothing between the two quote marks. If you want to use a period, change the comma to a period.) The third line is a little crazy, but it uses something called a regular expression to insert the separator every three digits, starting at the end.
    Here’s a project with all this set up so you can see.
