Activity Forums VEGAS Pro Scrolling is getting cut off
  • Scrolling is getting cut off
    Posted by Carson Young on July 4, 2007 at 2:00 am
    Hi everyone,
    I have a fairly lengthy quote that I would like to scroll up over about a 30 sec. period. I’m trying to achieve this with normal default text and pan/crop, but after I type so much it starts to cut off the top and then will not let me pan back down to view the top lines. What can I do to remedy this?
    Thanx,
    Carson
    Mike Kujbida replied 19 years, 2 months ago 2 Members · 3 Replies
  • Mike Kujbida
    July 4, 2007 at 2:33 am
    Forget using Pan/Crop in this case and use keyframes instead.
    Open up a text event.
    Change the text event size from 720 x 480 to something like 720 x 1,000.
    You can adjust the 1,000 value lower or higher later if necessary.
    Change the event length to 30 sec.
    Enter all your text.
    Go to the beginning of the event on the timeline in the text window.
    Change the Y value in the Placement tab so that the text is in the proper starting position (around 4.0).
    Create a key frame here.
    Go to the end of the event on the timeline in the text window and adjust the Y value so that the text is in the proper ending position (around -4.0).
    Create another keyframe.
    That should do it.
    Play it and see if this is what you want.
  • Carson Young
    July 6, 2007 at 12:33 am
    Worked awesome thanx Mike!!
  • Mike Kujbida
    July 6, 2007 at 3:25 pm
    Glad to hear that it worked for you 🙂
