Activity Forums VEGAS Pro scrolling credits stutter
  • scrolling credits stutter
    Posted by Sean Byron on May 7, 2009 at 6:45 pm
    Hi, I’m a newcomer to the site, and have been working(struggling)my way through Sony Vegas Pro 8 for the past year. I want to customize graphics for scrolling credits and they’re long, so I created a png file w/transparent background to play over a video clip, size is 300 dpi 720 width and the length is something like 9800. I set the keyframes – linear to slow, and selected reduce interlace flicker. All looks good when rendered as an avi, but when it gets rendered to the final mpeg it stutters, not a lot, but enough to be noticeable.
    I didn’t like using the credit scroll in Vegas, looked much worse for some reason.
    Can anyone help?
    THANKS! Sean
    Allen Zagel replied 17 years, 3 months ago 2 Members · 5 Replies
  • Allen Zagel
    May 8, 2009 at 1:04 pm
    Hi
    I believe that 300dpi may be too much. Have you tried 72-150 dpi on the fonts?
    Allen
    ASX Media Group, Inc.
    http://www.asxvideo.com
    NEW DVD – Europe, Trains-n-Trams
  • Sean Byron
    May 8, 2009 at 1:53 pm
    Thanks, I will try that!
  • Sean Byron
    May 9, 2009 at 11:08 pm
    I’m still at it, I tried to lower the resolution of the file, from 300dpi to 150 & 72. But I could see a loss in quality when I did that. I rendered it at 300 using the divX codec, and that worked even better for the .avi, but when I render to the .mpeg the stutter happens again. What am I missing? Help!!!
  • Allen Zagel
    May 11, 2009 at 1:18 am
    Hi Sean
    Well I don’t know what to offer. I winder if it could b3e in your MPEG settings.
    I’m having the same problem where I need to do what you did on a scrolling credit because I can’t seem to size the standard scrolling test the way I need.
    So I’ll suscribe to this thread and when I do mine I’ll get back to you. Hopefully this week.
    Maybe one of the other guru’s will jump in here.
    Allen
  • Allen Zagel
    May 16, 2009 at 9:32 pm
    Hi again Sean
    Okay finally got to that part of this project. I needed a scrolling credit and bouldn’t set the stock Vegas scroll the way I wanted to, so here’s what I did and it works beautiful. Haven’t rendered to MPG yet though.
    I brought up a regular text box and put all my text for scrolling in there. I always set the box sizes at 1440 X 960.
    After getting all the text set I put the text box on it’s own track and used the Track Motion to set the scroll. Wound up setting the keyframes to Linear for the best even scroll.
    I still got some tweaking and color corecting on the B-roll stuff, then I’ll run the DVD. It’s a music video of sorts, 1 set of a band playing about 11 songs, each will be a chapter.
    I didn’t use a graphics files for text. Didn’t need to. Just the text media.
    Allen
