  • Posted by Usman Janjua on June 1, 2014 at 8:30 pm
    Hi
    I have an image around 1000 x 3000 with text and lines but comp size is around 1000 x 450 which can get three lines . I’d like to start from top of image and begin scroll up to next line with ease out and stop with ease in and hold on the next line for maybe 4-7 sec and then again scroll like before for 2 sec to next line. I’d like to do this until image has scrolled all the way to the end. Is there an expression I could use to make it work? I’d also like to be able to adjust the scrolling afterwards if the scrolling doesn’t stop on the line and sync to audio which is reading the text. Hope this makes sense. Thanks in advance.
    Usman
    Jonan Grobler replied 12 years, 2 months ago 2 Members · 1 Reply
  • Jonan Grobler
    June 11, 2014 at 12:23 pm
    I think you’ll just have to use keyframes. To retime it later, select all the keyframes and hold ALT while you’re dragging the last keyframe in or out. Should work.
    Jonan Grobler
    Editor/Motion Graphics
