Activity Forums Adobe After Effects Expressions Scroll text with scale if/else
  • Scroll text with scale if/else
    Posted by Gus Favoreto on January 27, 2017 at 4:34 pm
    I am breaking my mind to find how and I research here and can’t find the solution. I hope be clear here. ☺
    I have a comp with 700px width, and 5 words align in x. But I want when that words pass between 270px and 400px of this comp scale to 100 them back to 75% when out this position. Ok I did for wich one separately(in this expression I put here), my question is: Can I put a Null and then this 5 words follow this null then they pass between this values they scale?
    My doubt is the value of x position the word is replace of de null, so the null will pass just one time in 270 and 400px.
    Thank you!
    Gus
    p = transform.position[0];
    if(p > 270 && p< 400){
    [100,100];
    }else{
    [75,75];
    Gus Favoreto replied 9 years, 7 months ago 2 Members · 7 Replies
  • 7 Replies
  • Dan Ebberts
    January 27, 2017 at 5:27 pm
    Try this:
    p = toComp(anchorPoint)[0];
    if (p > 270 && p < 400)
    [100,100]
    else
    [75,75]
    Dan
  • Gus Favoreto
    January 27, 2017 at 6:00 pm
    Dan, you are a genius!!
    This “toComp(anchorPoint)[0]” say to layer look his on anchor point?
    Gus
  • Dan Ebberts
    January 27, 2017 at 6:08 pm
    toComp() converts from layer space to comp space. A layer’s Anchor Point is always represented in layer space, so that’s what you need to use. You only need to use toComp() if the layer has a parent.
    Dan
  • Gus Favoreto
    January 27, 2017 at 6:10 pm
    Thank you!
  • Gus Favoreto
    January 27, 2017 at 6:12 pm
    Just one more question,
    To scale change smooth, not like a hold keyframe? I need to create a variable to replace the 270?
    Gus
  • Dan Ebberts
    January 27, 2017 at 6:28 pm
    Maybe something more like this:
    pMin = 270;
    pMax = 400;
    pMid = (pMin+pMax)/2;
    if (p < pMid)
    ease(p,pMin,pMid,[75,75],[100,100])
    else
    ease(p,pMid,pMax,[100,100],[75,75])
    Dan
  • Gus Favoreto
    January 27, 2017 at 6:45 pm
    Perfect!
    Thank you again!
    Gus
