Activity › Forums › Adobe After Effects Expressions › [Scripting] What Am I Doing Wrong?
  • [Scripting] What Am I Doing Wrong?
    Posted by Osama Sayegh on March 28, 2016 at 11:52 am
    Hey there,
    I want to add try and catch functions to several expressions. You know it’s painful to add them manually, so I decided to do that via scripting.
    var selComp = app.project.activeItem;
    var numSelLay = selComp.selectedLayers.length;
    var addExprBeg = "try { \r \r ";
    var addExprEnd = ";\r \r} catch(err) { \r \r value; \r \r}";
    for (i = 1; i <= numSelLay; i++) {
    var numSelProp = selComp.selectedLayers[i].selectedProperties.length;
    for (x = 1; x <= numSelProp; x++) {
    var Express = selComp.selectedLayers[i].selectedProperties[x].expression;
    selComp.selectedLayers[i].selectedProperties[x].expression = addExprBeg + Express + addExprEnd;
    I selected the layers and their properties that I wanted to add the try and catch functions to, and ran this code. It added the try and catch functions to the properties of the selected layer #2 only and didn’t touch the rest of the selected layers. What did I do wrong?
    If you have another way to do what I’m looking for, feel free to post it. I’m open-minded about new ways of doing things.
    Osama Sayegh replied 10 years, 6 months ago 3 Members · 3 Replies
  • Dan Ebberts
    March 28, 2016 at 5:18 pm
    I see a couple of things. Your array indexing (for selected layers and properties) should start a 0, not 1 (and end with <, not <=). Also, (I’m guessing) changing an expression probably changes what’s selected, so you will probably end up having to fist save all the selected properties into an array, and then process the array.
    Dan
  • Miguel De mendoza
    March 28, 2016 at 5:20 pm
    Short answer: selectedLayers and selectedProperties are arrays , that means that the first element is 0, not 1, is not the same when you are selecting layers through the layerCollection object: layer(1). So you must change your for loops consecuently:
    for (var i = 0; i < numSelLay; i++) {
    for (var x = 0; x < numSelProp; x++) {
  • Osama Sayegh
    March 28, 2016 at 6:01 pm
    YAY! Thanks a lot Dan and Miguel! Dunno how I forgot such a fundamental rule of coding 🙂
    Appreciate your time guys!
