Activity › Forums › Adobe After Effects › scripting tips
  • scripting tips
    Posted by Lars Fuchs on May 25, 2009 at 3:36 am
    Greetings all,
    In order to create animated textures for a 3D app, I need to convert an animated sequence of frames into a single large image with the individual frames scaled down and arranged into a grid. In other words, if I have a sequence that consists of 30 frames at 500×500, I would like to end up with a single image that has 6 rows of 5 100×100 images.
    I imagine that is is a reasonable job for scripting. However, although I have some experience with coding (C, Forth, etc many many years ago), I have no experience with JavaScript or scripting for AEfx. So I thought I’d ask the scripting veterans out there: is this relatively easy or difficult?
    Any suggestions on how I should approach it? My first thought is to use expression controls to get user input for the scaled down size of each image and the number of rows and columns, and to pick a folder of source images.
    Thanks in advance!
    BTW, I did try the Contact Sheet II function in PhotoShop. That NEARLY worked. It did arrange the images into a grid, but I didn’t get good registration; some of the images had extra space around the edge (about a pixel or so) that showed up when the texture was animated in the 3D app.
    Lars Fuchs replied 17 years, 4 months ago 2 Members · 2 Replies
  • Roland R. kahlenberg
    May 25, 2009 at 10:55 am
    Particle Playground’s grid emitter together with a persistent property mapper may do the trick. For a scripting solution, you may get a quicker response from the COW’s Expressions Forum.
    HTH
    RoRK
    broadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available).
    Adobe After Effects Training in South East Asia.
  • Lars Fuchs
    May 25, 2009 at 11:53 am
    Thanks… It never occurred to me to try Particle Playground! Excellent idea.
    And thanks for cluing me in about the expressions forum – i’ll repost there. I didn’t realize that it existed.
