Activity Forums Adobe After Effects Expressions SCRIPTING: Specify output Folder dialog
  • SCRIPTING: Specify output Folder dialog
    Posted by Barend Onneweer on June 12, 2012 at 2:09 pm
    Hi all,
    Not an expressions question but an ExtendScript question. But I get the impression this crowd might know a thing or two about After Effects scripting, too 😉
    So I’m taking Lloyd’s FXPHD scripting class and getting my feet wet in scripting. I’m trying to build a script that will create comps for all selected footage items, apply an animation preset and render to a specific location. Lloyd’s course is an excellent start since a good chunk of what I need is covered.
    But the thing I’m now strugling with is that I want the user to set the output path for the new files. So I’ve put in a ‘browse’ button, but the file.Opendialog isn’t what I need I think and I can’t figure out what I do need instead of this:
    var myOutputPath = File.openDialog("Select output path" );
    And there’s no such thing as Folder.openDialog it seems…
    Any pointers very much appreciated.
    Barend
    Raamw3rk – independent colourist and visual effects artist
    Barend Onneweer replied 14 years, 2 months ago 2 Members · 2 Replies
  • Dan Ebberts
    June 12, 2012 at 3:00 pm
    I think this is what you’re after:
    Folder.selectDialog(“your prompt goes here”);
    Dan
  • Barend Onneweer
    June 12, 2012 at 3:32 pm
    Ha! That’s so obvious – but I’ve browsed through the Javascript guide for quite a while and didn’t stumble upon it.
    Thanks a lot! And I’ll be back for more obvious answers soon 😉
    Barend
