Activity › Forums › Adobe After Effects Expressions › Scripting – Set Layer Selection
Posted by Kevin Snyder on October 20, 2022 at 4:37 amI have a script that applies an effect. The effect has a layer dropdown menu. I would like to change the layer selected by inputting a numeric value. I’m not sure if this is close.
var myComp = app.project.activeItem;
var myLayers = myComp.selectedLayers[0];
myParent = myLayers.effect("Parent Me")("Select Parent");
myParent.selection = 3;
Kevin Snyder replied 3 years, 10 months ago 3 Members · 8 Replies -
Andrei Popa
October 20, 2022 at 6:10 amI think this should work
myParent.setValue(3);
Kevin Snyder
October 20, 2022 at 2:46 pmThank you for your response. I gave it a go, but it doesn’t change the value. The effect is a pseudo-effect. Maybe that makes a difference?
Dan Ebberts
October 20, 2022 at 3:28 pmThat seems like the correct syntax, unless there’s something unusual going on. Maybe you can post a screen shot?
Kevin Snyder
October 20, 2022 at 4:06 pmI had another line of code that was interfering with it working. The last thing I would like to do is use the value from a text field box in the script to generate the number, but I might be going about it wrong.
var myIndex = edittext1.value;
myParent.setValue(myIndex);
Dan Ebberts
October 20, 2022 at 4:11 pmDepending on what edittext1 is, it might be:
var myIndex = parseInt(edittext1.text,10);
Kevin Snyder
October 20, 2022 at 4:44 pmMaybe I have something in the text field incorrect? I still can’t get it to parse the value. My text field in the script is as follows.
var edittext1 = group1.add('edittext {justify: "center", properties: {name: "edittext1"}}');
edittext1.text = "";
edittext1.helpTip = "Enter the parent layer index.";
edittext1.preferredSize.width = 40;
Dan Ebberts
October 20, 2022 at 8:15 pmSo you did change from .value to .text in your myIndex definition and it didn’t help?
Kevin Snyder
October 20, 2022 at 8:28 pmI just realized that var edittext1 from the UI was outside the function so the value from the field wasn’t being transferred. It’s working now. Thank you for your help!
