Activity › Forums › Adobe After Effects Expressions › Scripting server integration?
  • Scripting server integration?
    Posted by Adam Ghering on April 1, 2010 at 6:53 am
    I would like to write a script that will copy files from a network path to a local computer automatically on starting after effects. I am aware of the startup scripts folder.
    1. How do I call the server and feed it the password with after effects scripting. Is there an implimentation or do I have to do straight java?
    2. is there a way to copy paste from one directory to another once connected to the server.
    3. I would also be interested in knowing the proper syntax of pointing one script to another. I am familiar with nesting scripts. but if the two scripts arent in the same folder what is the syntax for navigating to the called scripts folder?
    Appreciate it.
    Adam Ghering replied 16 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
