Activity › Forums › Adobe After Effects › Scripting repetitive tasks
  • Scripting repetitive tasks
    Posted by Rob Hindley on September 5, 2005 at 7:55 am
    I have the task of producing on-air tv menus every week.
    Is there a way of automating the task using a central database that can insert/change text into an AE file then render out?
    The job only takes me less than half an hour but if I can automate this it would be great.
    Rob Hindley replied 21 years ago 2 Members · 2 Replies
  • Filip Vandueren
    September 7, 2005 at 12:34 pm
    You can write an applescript or vbscript that launches AE, then starts an AE Javascript.
    It’s do-able, but ask yourself, is it worth it, only to find out that the robot didn’t look at kerning, and how the text would flow better if that line-break was 1 word earlier etc.
    Perhaps you could find a go-between: design the text-layer in photoshop (should take you only a few minutes maybe) and insert that layer in an automated process that just adds the backgrouns and fades/wipes etc.
  • Rob Hindley
    September 7, 2005 at 9:04 pm
    thanks filip.
    the changes will only be single lines and four words maximum so no problem with kerning or text wrapping.
