Activity Forums Adobe After Effects scripting question…
  • scripting question…
    Posted by Danny Princz on September 25, 2006 at 7:22 pm
    i have a comp that im wokring with that id like to script the following.
    i have many layers lets call them, layer1, layer1_active, layer2, layer2_active, layer3, layer3_active, etc.
    im trying to write a script that when i select a layer, lets say layer1, i can run the script that for this example would apply some opacity keyframes, say, 100% 5 frames b4 the current time, 50% at the current time, 50% 5 frames later, etc.
    i understand the setValuesAtTimes, i just dont know how to get the current time to be a variable.
    how do i get the current comp time in the script?
    and then second.
    say the selected layer is layer1, then apply keyframes in a similayer manner to the layer1_active, ie the another layer that has the selecteds name plus a suffix?
    any ideas?
    Danny Princz replied 19 years, 11 months ago 2 Members · 7 Replies
  • 7 Replies
  • Dan Ebberts
    September 25, 2006 at 8:16 pm
    I think you get the layer time like this:
    var myComp = app.project.activeItem;
    var myLayer = myComp.selectedLayers[0];
    var myCurrTime = myLayer.time;
    and do this to get the layer with the suffix:
    var suffix = “_active”;
    var myNewLayer = myComp.layer(myLayer.name + suffix);
    Not tested, but should be close.
    Dan
  • Danny Princz
    September 25, 2006 at 8:38 pm
    thanks dan
    i was trying something like that for the time but couldnt get it to work.
    ill give it another go
  • Danny Princz
    September 25, 2006 at 8:45 pm
    it must be somthing else i am doing wrong as that is pretty much what i had
    i am an error that the value is not a float
    heres a test script
    var myCurrTime = myLayer.Time;
    keyTimes = new Array (1,2,myCurrTime);
    keyValues = new Array(10,20,30);
    myLayer.opacity.setValuesAtTimes(keyTimes,keyValues);
  • Dan Ebberts
    September 25, 2006 at 11:30 pm
    You just need to change:
    myLayer.Time;
    to:
    myLayer.time;
    Dan
  • Danny Princz
    September 26, 2006 at 2:38 pm
    ugh
    thanks so much
    i couldnt figure out why it wasnt working…
    i also have a layer expression effect that i would like to use to choose the layer that the script targets but i cant get that to work either.
    if i have an effect on myLayer named chooser
    var myTarget = myLayer.effect(“chooser)(“Layer”)
    so
    var myTarget = myLayer.effect(“chooser”)(“Layer”);
    myTarget.opacity.setValuesAtTimes(keyTimes,keyValues);
    what am i doing wrong here?
    thanks again
  • Dan Ebberts
    September 26, 2006 at 3:13 pm
    This seems to work:
    var myTarget = myComp.layer(myLayer.effect(“chooser”)(“Layer”).value);
    Dan
  • Danny Princz
    September 26, 2006 at 3:39 pm
    .value
    awesome
    thanks so much
    you are the man!
