Activity Forums Adobe After Effects Expressions Scripting question: Keyframe Interpolation control beyond only 2 options
  • Scripting question: Keyframe Interpolation control beyond only 2 options
    Posted by Paul Duncan on March 27, 2013 at 8:57 am
    Hello
    I’ve been trying to write a script which changes keyframe interpolation / spatial interpolation to LINEAR.
    (Right click a position keyframe, click ‘keyframe interpolation’, see 4 options under ‘spatial interpolation’.
    However, I understand the scripting control to be: app.item(x).layer(j).position.setSpatialAutoBezierAtKey(i, false);
    …where the boolean value at the end toggles between ‘continuous bezier’, and ‘auto bezier’, and this does not give access to the other two options available via the GUI i.e., ‘Bezier’, and ‘Linear’.
    Can anybody advise on how to achieve my goal?
    Coen Rens replied 10 years, 10 months ago 3 Members · 3 Replies
  • Jessica Ma
    May 27, 2015 at 9:50 am
    Hi I would like to know that too – and how to change keyfrm interpolation in an expression to hold.
    basically to do this tutorial in script instead of one by one key
  • Jessica Ma
    May 27, 2015 at 9:51 am
    tutorial
    https://www.youtube.com/watch?v=Rp7yGSYZeiM
  • Coen Rens
    October 17, 2015 at 1:34 pm
    Hi Paul,
    I’m aware that this response comes years after your post, but hopefully it’s useful for whoever finds this thread when searching for the same problem.
    I had the same problem and managed to solve it; the trick seems to be in the ‘setSpatialTangentsAtKey’ method
    In your case it would be:
    app.item(x).layer(j).position.setSpatialTangentsAtKey(i, [0,0,0], [0,0,0])
    where ‘i’ is the index of the key you wish to change, and the two arrays carry input for the tangents which are all set to zero. You can find a further explanation of this method on page 142 and 143 of the After Effects CS6 Scripting Guide.
    For me, setting all the tangents to 0 made the keyframes’ spatial interpolation show up as ‘Linear’ in the Keyframe Interpolation window, and caused the keyframes to behave as such.
    This solved my problem and should solve yours, I hope it helps someone else!
