Activity Forums Adobe After Effects Scripting question about shape layers
  • Scripting question about shape layers
    Posted by Nick Hill on September 22, 2022 at 12:27 pm
    I’m trying to make a script that creates a shape layer, then a group, then a (freeform) path, stroke and fill within that. This is what I’ve got – the createPath function doesn’t work, and causes AE to white-out and crash. Any ideas why?
    The script works fine if I comment that line out.
    var shp = createShape(comp);
    shp.name = ("Curve");
    var curvgrp = createShapeGroup(shp);
    curvgrp.name = ("CurveGrp");
    // var curv = createPath(curvgrp);  // COMMENTED BECAUSE IT KILLS AE
    var curvstrk = createStroke(curvgrp);
    var curvfll = createFill(curvgrp);
    function createShape(targetComp) {
            return targetComp.layers.addShape();
        function createShapeGroup(shape) {
            return shape.property("Contents").addProperty("ADBE Vector Group");
        function createPath(group) {
            return group.property("Contents").addProperty("ADBE Vector Shape");
        function createStroke(group) {
            return group.property("Contents").addProperty("ADBE Vector Graphic - Stroke");
        function createFill(group) {
            return group.property("Contents").addProperty("ADBE Vector Graphic - Fill");
    Nick Hill replied 3 years, 11 months ago 2 Members · 5 Replies
  • Filip Vandueren
    September 22, 2022 at 12:38 pm
    You’d need to add a (“ADBE Vector Shape – Group”) to (“Contents”) before you can add the (“ADBE Vector Shape”) to that new Group
  • Nick Hill
    September 22, 2022 at 12:53 pm
    Thanks Filip. So that’s an extra step after adding the ADBE Vector Group?
    Would this work for the createPath function:
    group.property(“Contents”).addProperty(“ADBE Vector Shape – Group”);
    return group.property(“Contents”).addProperty(“ADBE Vector Shape”);
    …or does the ADBE Vector Shape have to sit within the ADBE Vector Shape – Group?
  • Nick Hill
    September 22, 2022 at 1:11 pm
    If I change createPath to this, it works. So what’s the difference between a parametric path and a freeform one, in terms of how AE references them?
    return group.property(“Contents”).addProperty(“ADBE Vector Shape – Star”);
  • Filip Vandueren
    September 22, 2022 at 3:56 pm
    Hi Nick,
    I’m not sure why. I don’t have a scripting setup available at the moment to test, sorry.
  • Nick Hill
    September 22, 2022 at 4:04 pm
    don’t worry, this works:
    return group.property(“Contents”).addProperty(“ADBE Vector Shape – Group”);
    thanks for your help!
