Activity Forums Adobe After Effects Expressions scripting question
  • scripting question
    Posted by Ryan Rusnak on May 21, 2009 at 5:15 pm
    Hello,
    Please forgive my ignorance. What I am trying to do is: having two layers selected, upon the running of this script, both layers to move their anchor points to the edge of the layer on x and the middle of the layer on y while the lowest in the timeline changes position. I don’t care where it repositions to yet, just that it moves so I threw “width” and “height” in just for a test.
    From my understanding the following line of code should move the lowest of the selected layers to a new position.
    var myPosition = myComp.selectedLayers[1].property(“position”);
    myPosition.setValue([myWidth, myHeight]);
    and it does. but If I change the [1] to a [0] it makes no difference. It still moves the lowest layer. Can someone please explain to me why and how to fix this?
    My second concern is that when it does move, it moves to [0.0,0.0] rather than what I would expect which is [500,10] the layers height and width. The anchor point moves to [0,0] as well and I want it to move to [0,5]. Can anyone explain this to me?
    I started learning scripting yesterday so the answers may be really simple. Below is my whole script as it is right now. Thanks a lot, Ryan
    app.beginUndoGroup(“snap”);
    var myComp = app.project.activeItem;
    for (i=0; i
    Ryan Rusnak replied 17 years, 3 months ago 2 Members · 3 Replies
  • Dan Ebberts
    May 21, 2009 at 6:21 pm
    width and height are layer attributes, not properties. So you should do something like this:
    var myWidth = mySolid.width;
    var myHeight = mySolid.height/2;
    FYI – when you paste code into this forum, you’ll want to make sure you leave a space before and after your less-than and greater-than operators or a bunch of your code may get interpreted as html (like happend to your for loop). Or, you could use the entry panel provided for posting expressions, but that comes with its own set of challenges.
    Dan
  • Ryan Rusnak
    May 21, 2009 at 6:50 pm
    Thanks a lot Dan, for your help.
    Thanks, Ryan
  • Ryan Rusnak
    May 21, 2009 at 7:57 pm
    Ok, I have things working but I am now encountering a new challenge. I think that I need to convert comp space to to the layer space of a particular layer. Does any one know how to do that? I’ve searched and am still searching but have not found anything yet.
    In the code below, I want the value in the first dimension of the array to be the edge of the layer selectedLayers[0]. The number that I am getting now is correct but I think it is in comp space rather than layer space.
    myPositionTwo.setValue([myComp.selectedLayers[0].width, myHeight]);
    below is my updated code. Thanks a lot, Ryan
    app.beginUndoGroup("snap");
    for (i = 0; i < 1; + + i ){
    if (myComp.selectedLayers.length < = 1 || myComp.selectedLayers.length > = 3){
    alert("please select two layers");
    }else{
    var mySolid = myComp.selectedLayers[i];
    var myAnchor = mySolid.property("anchorPoint");
    myAnchor.setValue([myWidth,myHeight]);
    var myPositionTwo = myComp.selectedLayers[1].property("position");
    var myPositionOne = myComp.selectedLayers[0].property("position");
    app.endUndoGroup();
