Activity Forums Adobe After Effects Expressions Scripting Question
  • Scripting Question
    Posted by Nicholas Petersen on May 31, 2013 at 12:18 pm
    I know that this is not strictly a question about expressions, but given that there is no dedicated scripting forum, I reasoned that this would be the most appropriate forum. Apologies if I am mistaken.
    I’m curious about editing expression controls within the scripting language, specifically how to change the name of each expression control. Here’s where I’m stuck…
    app.project.activeItem.layer(4).effect.addProperty(“Slider Control”);
    app.project.activeItem.layer(4).effect.(“Slider Control”).name = “Raise/Lower Arm”;
    I’ve been pawing through the scripting guide, but I have not been able to find anything about changing an expressions name. I tried this, thinking that it might work, and obviously it didn’t, as I got the following error message:
    “Function (predicate expression) cannot work with this class””
    What do I need to do to change the name of an expression control using the scripting language?
    Thanks for your help!
    Nic
    app.project.activeItem.layer(4).effect.addProperty("Slider Control");
    app.project.activeItem.layer(4).effect.("Slider Control").name = "Raise/Lower Arm";
    Nicholas Petersen replied 13 years, 3 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 31, 2013 at 2:10 pm
    I’d do it this way:
    var myEffect = app.project.activeItem.layer(4).effect.addProperty(“Slider Control”);
    myEffect.name = “Raise/Lower Arm”;
    Dan
  • Nicholas Petersen
    June 1, 2013 at 10:14 pm
    Thanks! Worked like a charm!
    Nic
