Activity Forums Adobe After Effects Expressions Scripting Question
  • Scripting Question
    Posted by Paul Benson on November 28, 2009 at 6:40 pm
    Trying to move up to scripting, and this is the closest forum I can find on the cow. I have seen something like this is a few scripts, and there is an example in the javascript tools guide for CS3. Essentially, the code is using a string as an array index. I’m not sure how this works. I’m thinking it is not a true array, so any insight is appreciated. Here is a code snippet which shows the values of all the properties of an object:
    var f = new File ("myfile");
    var props = f.reflect.properties;
    for (var i = 0; i < props.length; i++) { $.writeln('this property ' + props[i].name + ' is ' + f[props[i].name]); }
    How does the f[props[i].name] get decoded? props[i].name is a string. Is this some alternate method to access object properties? Like if props[i].name = "path", then this will output f.path? That's what it implies to be doing, but I haven't seen this specifically addressed.
    Pauley
    Paul Benson replied 16 years, 9 months ago 2 Members · 3 Replies
  • Paul Benson
    November 28, 2009 at 7:02 pm
    Hmmm, well I’m still trying to wrap my head around it, but I did find this explanation.
    You can access ReflectionInfo objects in a Reflection object’s properties and methods arrays, by name or index:
    obj = new String ("hi");
    obj.reflect.methods[0];
    obj.reflect.methods["indexOf"];
    I assume this is not unique to ReflectionInfo objects. I’m still trying to visualize this. Seems like a nice shortcut to get the the parameters/properties you want.
    Pauley
  • Dan Ebberts
    November 28, 2009 at 8:19 pm
    In JavaScript, objects are also associative arrays, which can be accessed using strings. There’s a lot of info out there on JavaScript objects and associative arrays. Google is your friend. 🙂
    Dan
  • Paul Benson
    November 28, 2009 at 8:32 pm
    Thanks Dan. The problem with google is that my search results always gave back links to basic array methods and properties. Now I know how to properly phrase my search with “associative arrays”. Your post should help me narrow down my search.
    Pauley
