Activity Forums Adobe After Effects Expressions Scripting (not expressions): Setting the layer’s “active” property?
  • Scripting (not expressions): Setting the layer’s “active” property?
    Posted by Quba Michalski on September 22, 2014 at 11:33 pm
    I am trying to figure out how can I set the layer’s active property to false (turn off the little eye icon via script). using setValue() and simple =false commands results in either an error or a read-only value prompt.
    Is it possible to do so (and no, if possible I’d like to avoid resorting to just setting opacity to 0).
    mypLayer.active.setValue(false);
    Quba Michalski
    qubahq.com
    Dan Ebberts
    replied 8 years, 9 months ago
    3 Members · 6 Replies
  • Dan Ebberts
    September 22, 2014 at 11:40 pm
    It’s an attribute, so you can just set the value:
    mypLayer.active = false;
    Dan
  • Quba Michalski
    September 22, 2014 at 11:48 pm
    …it does not seem to work 🙁
    So I have a composition in my project already assigned to the name of “depthMapComp”
    I successfully add it to my current composition (theComp), but get that “read only attribute” error when I try to change its active state
    var depthMapLayer = theComp.layers.add(depthMapComp);
    depthMapLayer.active = false;
    Quba Michalski
    qubahq.com
  • Dan Ebberts
    September 22, 2014 at 11:59 pm
    Ah yes, sorry–that slipped right by me. Try enabled instead of active.
    Dan
  • Quba Michalski
    September 23, 2014 at 12:07 am
    Dan Dan Dan the Man
    Dan’s the Man, da-dan-da-da-dan
    Dan’s the Man, Dan’s the one,
    None gets done sans Dan the Man
    Thank you!
    Quba Michalski
    qubahq.com
  • Vishal Jain
    December 8, 2017 at 11:32 am
    Revisiting this after a long time.
    How can I link this to a checkbox?
    I am trying to make a pseudo effect for After Effects where the user can choose a layer active or not simply clicking the checkbox. Since the number of layer is >20, I will be using shy-layers.
    Please help!
    mypLayer.enabled = false;
    Photoshop
    After Effects
    Cinema4D
    Vizrt
  • Dan Ebberts
    December 8, 2017 at 7:25 pm
    You can’t control the enabled state with expressions. I think the best you could do would be to control the opacity.
    Dan
