Activity › Forums › VEGAS Pro › Scripting Job – Quotes needed
  • Scripting Job – Quotes needed
    Posted by David Timar on June 22, 2007 at 7:36 am
    I would like the scripting pros to check out this post and if possible give me a quote on writing 2 scripts for Vegas.
    1. TEXT CONVERTER
    I usually have over 100 individual text objects on my timeline, as subtitles. I need a script to convert that 1 timeline into an .srt, text file, or anything I can use to create DVD subtitles.
    2. MASS TEXT MODIFIER
    I need a script to look at a selected timeline and change one/more attributes of all the text objects in that timeline. Attributes I must be able to modify:
    – font type
    – font size
    – bold/italic
    – font position (top left, top right, coordinates, etc.)
    Would be nice to be able to change:
    – font color (I am fine with entering a 6 digit color code number)
    – shadow
    – outline
    – anything else…
    David Timar
    Edward Troxel replied 19 years, 3 months ago 3 Members · 7 Replies
  • 7 Replies
  • David Timar
    June 22, 2007 at 7:37 am
    Oops. In case you don’t want to post the price here, send me a letter to tdavid232 AT gmail.com .
  • Mike Kujbida
    June 22, 2007 at 9:30 am
    For your text converter, do a google search on vegas SubText and you’ll find a free one in the first few links that come up.
    From the site:
    Create your subtitles in Microsoft Word or other text editor, and apply this application. You can even import DVD Architect .SUB files. SubText will then place/generate regions into your project with the subtitle as the label, saving you enormous amounts of time. Your text must be in .txt or .sub format; SubText won
  • David Timar
    June 22, 2007 at 9:49 am
    Hello Mike,
    To the best of my knowledge Subtext doesn’t actually take text media objects on a timeline and converts them. It does that with regions.
    Or am I wrong?
    David
  • Mike Kujbida
    June 22, 2007 at 10:19 am
    David, I haven’t tried the program so I can’t answer your question.
    Sorry 🙁
  • Edward Troxel
    June 22, 2007 at 1:25 pm
    David, what you’re wanting to do can’t be done via scripting. Scripts can’t access the individual text or attributes – it can only set presets.
    Edward Troxel
    JETDV Scripts
  • David Timar
    June 22, 2007 at 1:36 pm
    Hello Edward,
    In that case, is there a way to apply a preset to all text events on a timeline?
    Also, I still don’t understand how the presets that come with Vegas, if applied to a text, DO change the attributes of that text, BUT not the text itself. When I save a text preset, and apply it to another text event, it overwrites the text itself, making the preset pretty much useless.
    Any thoughts on that?
    David
  • Edward Troxel
    June 23, 2007 at 12:15 pm
    If you use a script to change the presets, you’ll also change the text.
    Edward Troxel
    JETDV Scripts
