Activity Forums Adobe After Effects Expressions Scripting : I’ve noticed something weird in scripting. Can anyone Explain why and how this is happening?
  • Scripting : I’ve noticed something weird in scripting. Can anyone Explain why and how this is happening?
    Posted by Adirai Maji on December 29, 2019 at 1:58 pm
    I’ve created two different scripts to do two different tasks. In both scripts I’ve dialog boxes.
    I call the dialog function with same function name since they’re two different sctipts I didn’t had a thought that they meshup with each other. When I click the dialog button on each script they work fine…..Until one of the scripts not being running in After Effects. But If I run both script’s UI on AE and press the dialog button on either of those scripts it only pops up dialog which is related to one script. I’ve resolved this issue by changing the function name of one dialog box.
    Why is this happening? What If I want to use same function name on two different scripts????
    Thanks in Advance…
    – Adirai Maji
    Tomas Bumbulevičius replied 6 years, 8 months ago 3 Members · 4 Replies
  • Dan Ebberts
    December 29, 2019 at 8:34 pm
    An easy way to keep from cluttering AE’s namespace with your function names is to make sure everything in enclosed in a single function with a unique name, like this:
    function AndiraiMaji_01(){
    // your script here
    AndiraiMaji_01();
    Dan
  • Tomas Bumbulevičius
    January 2, 2020 at 12:55 pm
    Hey Dan, in such scenario – could you suggest what is the best way to treat global variables? Because if there are some affected variables inside the function, they will stay local within that ‘custom’ function. \
    Should it be done by building object of variables to be returned or is there a better way?
    Find out more:
    After Effects Tutorials: motion design, expressions, scripting.
    Boxer – Dynamic Text Boxes Template with a Live Preview
  • Dan Ebberts
    January 2, 2020 at 5:26 pm
    That depends on what you mean by global. When I want something to be accessible from anywhere within my script, I declare an object just inside my enclosing function, like this:
    function de_NewScript(){
    // globals
    var G = new Object();
    G.scriptName = "Dan's New Script";\
    // functions
    function myUtilityFunction(){
    // function code here
    // main code
    de_NewScript();
    But if I need something global that two scripts can use to communicate, I would generally attach it to the app (maybe not recommended, but it seems to work):
    app.de_object = {};
    app.de_object.script1Present = true;
    Dan
    January 3, 2020 at 6:45 am
