Activity Forums Adobe After Effects Expressions (Scripting) – Is there a way to determine if a layer style exists?
  • (Scripting) – Is there a way to determine if a layer style exists?
    Posted by Scott Higgs on February 4, 2010 at 12:15 am
    Sorry if this is not the right forum for AE scripting questions – it’s the closest I could find.
    When I try to determine whether or not a layer has a drop shadow layer style applied using the code below, I always get TRUE, even if the layer in question has no drop shadow applied. Likewise checking its distance value always gives the default 5 (unless a drop shadow has actually been applied, in which case I get the correct distance value).
    Do the propertyGroup objects for Layer Styles and Drop Shadow always exist somewhere behind the scenes? I just need to determine if a layer has a visible drop shadow or not. I feel like I must be missing something obvious…
    Thanks in advance.
    alert(curLayer.layerStyle.property("Drop Shadow").enabled);//yields true
    alert(curLayer.layerStyle.property("Drop Shadow").property("Distance").value); //yields 5 if no D.S. applied
    -Scott
    Dan Ebberts replied 16 years, 7 months ago 2 Members · 1 Reply
  • Dan Ebberts
    February 4, 2010 at 4:15 am
    I don’t know of any way to detect that, sorry.
    Dan
