Activity Forums Adobe Premiere Pro Scripting in Premiere Pro – Where to start
  • Scripting in Premiere Pro – Where to start
    Posted by Ryan Mcadam on April 13, 2016 at 6:47 pm
    I’ve been writing automation scripts in After Effects for a while now and am familiar with the process and documentation.
    I’d like to write some similar scripts for Premiere CC(2015) ,but finding any material on the topic has proven difficult. I did find Premiere’s Plug-in and pannel SDKs from the adobe developer site.
    https://www.adobe.com/devnet/premiere.html
    Didn’t really help with the whole getting started process.
    Does anyone know of a good guide or tutorial on getting up and running with scripting for Premiere Pro CC(2015)?
    Ryan
    Ivan Stepanov replied 7 years, 1 month ago 13 Members · 18 Replies
  • 18 Replies
  • Herb Sevush
    April 14, 2016 at 12:58 pm
    [Ryan McAdam] “I’ve been writing automation scripts in After Effects for a while now and am familiar with the process and documentation.”
    Ppro doesn’t have any “scripting” abilities – you can make third party plug-ins, which is something I know nothing about, but there is no scripting automation similar to what you have in AE.
    Herb Sevush
    Zebra Productions
    nothin\’ attached to nothin\’
    \”Deciding the spine is the process of editing\” F. Bieberkopf
  • Alex Udell
    April 14, 2016 at 3:00 pm
    Hi….
    What kinds of things are you thinking about automating?
    Alex Udell
    Editing, Motion Graphics, and Visual FX
    Let’s Connect on Linkedin
    Examples: Retail Automotive Motion Graphics Spots
    Example: Customer Facing Explainer Video
    Example: Infotainment & Package editorial
  • Ryan Mcadam
    April 14, 2016 at 4:17 pm
    I was hoping to set up a project system for my team. Currently when a team member needs to link to an asset in a project, they need to navigate the folder structure in Dropbox. That sounds simple enough, but our folder structure gets very complicated with different assets and versions, naming conventions and file types. Team members also tend get into the project folders and create sub folders they shouldn’t or move/rename things they shouldn’t move or rename.
    I’m writing a set of tools for after effects that manages all this stuff in the background so team members can access everything they need without wasting time navigating the project files or messing with anything in the project folder.
    I’d like to create a similar system for premiere so my video editor can click a button and bring in the most updated file versions without having to go looking for them.
    Premiere has a panels sdk (different from the plug-in sdk) that may do the trick but it seems more complex then AE’s scripting language and not well documented.
    Any thoughts you have on the topic would be great. Thank you.
  • Ryan Mcadam
    April 14, 2016 at 4:18 pm
  • Alex Udell
    April 14, 2016 at 6:36 pm
    Hey Ryan….
    unfortunately I don’t have any insight to the scripting in Ppro…
    and I looked a while ago as well….lack of documentation may be intentional at this point….as it might not be as mature as what you’d find in AE.
    but if you are looking for a project system take a look at this:
    https://frame.io/premiere
    may be of some help….and you might not need to code at all…
    Alex Udell
  • Shawn Baden
    February 23, 2017 at 11:49 pm
    Hey Ryan,
    Not sure where you are with your Premiere scripting but I’m in the same boat as you. I am very familiar with scripting for AE and am now trying to fumble my way blindly through scripting for Premiere.
    I’m using Extendscript, like I do for AE and running the scripts from there – I can’t find a way to run the scripts from inside PPro. The only way I know to run them from within PPro is to build a panel – I’ve been trying to figure that out as well.
    There is now a little bit more documentation but still not much. Adobe has done a very poor job of supplying documentation. Here are a few links straight from Adobe:
    Very limited api:
    https://github.com/Adobe-CEP/Samples/blob/master/PProPanel/payloads/api_doc.html
    Sample scripts:
    https://github.com/Adobe-CEP/Samples/blob/master/PProPanel/jsx/Premiere.jsx#L314
  • Peter Garaway
    February 24, 2017 at 12:37 am
    Hi Ryan,
    Are you still looking for some help here?
    Shawn – I’ll see if I can find out anything.
    Peter Garaway
    Adobe
    Premiere Pro
  • Ryan Mcadam
    February 24, 2017 at 3:29 am
    Yes,
    I’m still looking. Anything you have would be great.
    Ryan
  • Peter Garaway
    February 24, 2017 at 5:13 pm
    Hi Ryan –
    Email me at pgaraway at adobe dot com
    I’ll connect you with someone that can lead you in the right direction.
    Peter Garaway
    Adobe
    Premiere Pro
  • Anna Komarova
    March 30, 2017 at 2:53 pm
    Hi, Ryan!
    Have you found out how to set up a project system?
    If yes, please, share your solution.
    I have practically the same task.
    Thank you!
