Activity Forums Adobe After Effects Expressions [Scripting] How can I add Animator properties such as (Scale), (Fill Color RGB) to a text layer using extendscript?
  • [Scripting] How can I add Animator properties such as (Scale), (Fill Color RGB) to a text layer using extendscript?
    Posted by Adirai Maji on March 7, 2020 at 3:17 pm
    I want to know how can I add animator properties to a text layer. As far as I’ve searched I can only able to create “Animator 1” group under animator properties in After Effects scripting. I can’t find a way to add properties into it. Can anybody help me to do that?
    This is what I have so far ????
    app.project.activeItem.layer(1).Text.Animators.addProperty("ADBE Text Animator")
    Thanks in Advance…
    – Adirai Maji
    Adirai Maji replied 6 years, 5 months ago 2 Members · 3 Replies
  • Andrei Popa
    March 9, 2020 at 7:41 am
    Most of the properties:
    var anim = app.project.activeItem.layer(1).Text.Animators.addProperty("ADBE Text Animator");
    //add range selector
    anim("ADBE Text Selectors").addProperty("ADBE Text Selector");
    var animProperties = anim("ADBE Text Animator Properties");
    //Add properties
    //andchorPoint
    animProperties.addProperty("ADBE Text Anchor Point 3D");
    //position
    animProperties.addProperty("ADBE Text Position 3D");
    //scale
    animProperties.addProperty("ADBE Text Scale 3D");
    //skew
    animProperties.addProperty("ADBE Text Skew");
    //skew axis
    animProperties.addProperty("ADBE Text Skew Axis");
    //rotation
    animProperties.addProperty("ADBE Text Rotation");
    //Opacity
    animProperties.addProperty("ADBE Text Opacity");
    Andrei
    My Envato portfolio.
  • Andrei Popa
    March 9, 2020 at 7:45 am
    To get more of the matchNames, use rd_gimmePropPath on those properties, after you manually added them.
    Andrei
  • Adirai Maji
    March 10, 2020 at 5:38 am
    Thank you so much. It helped.
    Thanks in Advance…
    – Adirai Maji
