Activity Forums Adobe After Effects Expressions Scripting date Modified or creation
  • Scripting date Modified or creation
    Posted by Davis Lindsay on July 2, 2013 at 3:00 pm
    Hello,
    I’m swinging in the dark a bit for this one…
    Is it possible to use a .lastModified method with extended script?
    Or would it be easier to generate a txt file then link to that?
    my current code is giving me an “invalid date” error.
    In the alert it displays
    ,Invalid Date,[file path]
    var proj = app.project;
    var comp = proj.item(2);
    var movFolder = app.project.item(3)
    var movs = app.project.item(3).numItems;
    var newSource = movFolder.item(1);
    var fso, f, s;
    f = File("/slate script/projects"+newSource.name);
    var lastModifiedDate = new Date(newSource.lastModified);
    fso = newSource.lastModified;
    alert([fso, lastModifiedDate, f])
    Davis Lindsay replied 13 years, 2 months ago 2 Members · 2 Replies
  • Dan Ebberts
    July 2, 2013 at 5:54 pm
    A few things– you could verify your path is correct by adding
    if (f.exists) alert(“File exists.”);
    after your definition of f.
    Also, I think the attribute you want is “modified”.
    You also might need to escape(newSoure.name) before you add it into the path.
    Dan
  • Davis Lindsay
    July 2, 2013 at 11:26 pm
    Wow, that was so easy;
    Tunnel vision totally had me there.
    Thanks Dan
    var fso, f, s;
    f = File("/slate script/projects/"+newSource.name);
    var lastModifiedDate = new Date(f.created);
    if (f.exists) alert("File exists.");
    alert([lastModifiedDate, f])
