Activity Forums Adobe After Effects Expressions Scripting changes from AE4 to CS6?
  • Scripting changes from AE4 to CS6?
    Posted by Shane Betts on May 22, 2013 at 3:50 am
    Hi guys
    Sorry for the dopey question but I’m trying to set up an expression in CS6, using an example (or examples) I found on the net in some old tutee for AE4. But, when I paste the sample expression into my CS6 comp, it returns errors, the prime one being “Expected: ;” in Line 2.
    Anyone with any thoughts? Thanks heaps in advance.
    Cheers
    Bettsy
    if ($.os.indexOf("Mac") != -1)
    myPath = "/ae_texts/";
    else
    myPath = "file://c:ae_texts";
    myPath += "text_1.txt";
    $.evalFile (myPath);
    eval(thisComp.name);sentences = type.split("$");
    m = thisLayer.marker.nearestKey(time);n = m.index;
    if (time < thisLayer.marker.nearestKey(time).time) {n = n-1}
    subtitle = sentences[n];
    subtitle
    Shane Betts replied 13 years, 3 months ago 2 Members · 7 Replies
  • 7 Replies
  • Dan Ebberts
    May 22, 2013 at 4:39 am
    One thing I see is that the second line shouldn’t have the semicolon at the end.
    Dan
  • Shane Betts
    May 22, 2013 at 1:06 pm
    Thanks Dan. I remove that and now it has a problem with the if/else statement, which it doesn’t seem to recognise as one and calls the use of the reserved word illegal. Confusing…
    Cheers
    Bettsy
  • Dan Ebberts
    May 22, 2013 at 1:21 pm
    This doesn’t generate any errors for me:
    if ($.os.indexOf(“Mac”) != -1)
    myPath = “/ae_texts/”
    else
    myPath = “file://c:ae_texts”;
    myPath += “text_1.txt”;
    Dan
  • Shane Betts
    May 22, 2013 at 1:25 pm
    Hey thanks Dan! You rock. I’ll try that and work outwards from there, although I can probably get by without the extra goodies anyway.
    Cheers
    Bettsy
  • Shane Betts
    May 24, 2013 at 10:01 am
    Hey Dan
    Finally had the chance to try that. For me this returns the file path as the text in the composition. In other words, my comp now displays /ae_texts/text_1.txt rather than the content of that file or any warning that it can’t find or read the file.
    Cheers
    Bettsy
  • Dan Ebberts
    May 24, 2013 at 2:48 pm
    That was just to fix the first error message you were getting–it was just meant to replace the first five lines of your expression.
    The only other thing I can see that doesn’t look right is the “<” character in the last if statement has been replaced with the HTML equivalent, but that could have happened when you pasted your code into the forum if you did a Preview Post before posting it, so it may not be that way in your original code.
    Dan
  • Shane Betts
    May 24, 2013 at 2:52 pm
    Hey Dan. I really appreciate your time on this. I have trolled this forum a little more and I believe I have found another post of yours with a solution.
    I’ll also look out the html substitution when I’m working from online tutes.
    Thanks mate!
    Cheers
    Bettsy
