Activity Forums Adobe After Effects Expressions Scripting challenge?
  • Scripting challenge?
    Posted by Tim Boknecht on July 16, 2012 at 9:07 pm
    I’d like to set up a script that will take a 1080 clip, split the clip into a grid of 15 384×384 squares, and use them to automatically populate 15 cube face precomps – a la the “Beginning” in the following example:
    Example
    A couple notes: I realize that 384*3=1152 and that I only have 1080 to work with. Not sure if/how that affects the desired effect. I also realize that in the example I’ve given, the “beginning” placeholder is not the result of slicing an original 1920×1080 image into 384 squares. I simply created a placeholder.
    Tim Boknecht
    Media Producer
    Bravo Productions
    Tim Boknecht replied 14 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
