Activity › Forums › Adobe After Effects Expressions › Scripting – Centre Mask on Shape Layer
  • Scripting – Centre Mask on Shape Layer
    Posted by Liam Carlin on March 7, 2022 at 10:17 am
    Hey Guys,
    I have created this snippet of code that creates a rectangle mask on any layer given it’s dimension. It works fine on all layers except Shape Layers and Text Layers. I can’t quite figure where I’m going wrong. It doesn’t centre when I thought it would. How do I center the mask?
    The image show’s how it’s not cantered.
    myLayer = app.project.activeItem.selectedLayers[i];
    newMask = myLayer.Masks.addProperty(“ADBE Mask Atom”);
    myProperty = newMask.property(“ADBE Mask Shape”);
    newMask.name = “Rectangle Mask”;
    newMask.maskMode = MaskMode.ADD;
    myShape = myProperty.value;
    myShape.vertices = [[myLayer.width,0],[0,0],[0,myLayer.height],[myLayer.width,myLayer.height]];
    myShape.inTangents = [[0,0],[0,0],[0,0],[0,0]];
    myShape.outTangents = [[0,0],[0,0],[0,0],[0,0]];
    myShape.closed = true;
    myProperty.setValue(myShape);
    Liam
    Liam Carlin replied 4 years, 6 months ago 2 Members · 4 Replies
  • Filip Vandueren
    March 7, 2022 at 12:10 pm
    Hi Liam, shape layers and textlayers – because they are rasterized continuosly- behave as if they always are a composition-sized layer.
    Using an exprerssio with sourceRectAtTime(), you can get the correct dimensions, although for some shapes it may or may not include the stroke-width.
    For example, see this question from yesterday:
    https://creativecow.net/forums/thread/mask-path-shape-to-always-match-text-total-scale-and-width/
    Mask Path Shape to always match text total scale and width
  • Liam Carlin
    March 8, 2022 at 4:20 am
    Thanks Filip,
    That makes sense. I have previously used sourceRectAtTime(); on text layers before.
    However I don’t actually know how to implement this. Are you able to see where I am going wrong.
    Liam
    app.beginUndoGroup("Undo Rectangle Mask");
    newMask = myLayer.Masks.addProperty("ADBE Mask Atom");
    myProperty = newMask.property("ADBE Mask Shape");
    newMask.name = "Rectangle Mask";
    sr= myLayer.sourceRectAtTime();
    pts= [
    [sr.left, sr.top],
    [sr.left+sr.width, sr.top],
    [sr.left+sr.width, sr.top+sr.height],
    [sr.left, sr.top+sr.height],
    createPath(pts,[],[],true);
    myLayer.sr;
    app.endUndoGroup();
  • Filip Vandueren
    March 8, 2022 at 7:19 am
    Hi Liam, the example I posted was an expression, the syntax and methods are a bit different.
    In a script it would be like this:
    app.beginUndoGroup("Rectangle Mask");
    myLayer = app.project.activeItem.selectedLayers[0];
    sr= myLayer.sourceRectAtTime(myLayer.time,true);
    [sr.left, sr.top],
    app.endUndoGroup();
  • Liam Carlin
    March 8, 2022 at 11:22 am
    Thanks incredible, thank you Filip! It makes a lot of sense. Thanks for your time 👍
