Activity Forums Apple Final Cut Pro Legacy Scripting / Automating bulk clip renames
  • Scripting / Automating bulk clip renames
    Posted by Rob Mcdougall on January 25, 2011 at 5:27 pm
    Is there any way in FCP to batch rename clips etc. ?
    I used to help manage a render farm for a VFX company and we had a load of shake scripts for renaming, so if you wanted to change:
    Whatever_Here_001_v3.dpx
    to
    whatever_here_001_v3.dpx
    you’d input filename in, filename out with a $$$ over the sequence numbers.
    What I’d really like to be able to do is change:
    Some Random Mess Cam 003 – 010110
    and
    Some Other Random Mess 3 – 010110
    to
    My Actual Name Cam 003 – 010110
    so I need some sort of find / replace. I can’t see any way of getting scripting into FCP. Can I export XML and play with it in filemaker without breaking it?
    Jeff Greenberg replied 15 years, 8 months ago 2 Members · 3 Replies
  • Jeff Greenberg
    January 26, 2011 at 1:06 pm
    Are you meaning clips inside of FCP? or the files that FCP is managing.
    If it’s the files outside of FCP, I love name mangler.
    If it’s the files inside – I’d have to think about that. Yes, there might be an XML way.
    Best,
    Jeff G
    Apple Master Trainer
    Avid Cert. Instructor DS/MC
    Avid & Color Videos Vasst.com
    Compressor Essentials Lynda.com
  • Rob Mcdougall
    January 26, 2011 at 1:34 pm
    I suppose what I’m really after is a better way of managing clip names in FCP. Is it possible to trawl through the XML and do Find + Replace without breaking it? That way I could then use Rename>File as Clip Name
  • Jeff Greenberg
    January 26, 2011 at 2:35 pm
    Dicey.
    The issue is that you’d want to change the internal name in FCP and leave the source alone. Tough; I’d test it with the XML and a decent text grep search/replace. Easier to do it at the finder level and reimport from scratch.
    Best,
    Jeff G
