Activity Forums Adobe After Effects Scripting: Add loopOut() Expression to a selectedLayer with a script?
  • Scripting: Add loopOut() Expression to a selectedLayer with a script?
    Posted by Brandon Smith on February 6, 2013 at 2:18 am
    I am beginning to learn scripting, so I am starting off with some simple shortcut scripts. One that I am having a hard time trying to make is a script that will apply the loopOut() expression to the Position property of the layer that I have selected (or multiple selected layers). This layer already has the necessary keyframes to let the loopOut() expression work.
    Any help is greatly appreciated.
    Brandon
    Brandon Smith replied 13 years, 7 months ago 3 Members · 3 Replies
  • Vishesh Arora
    February 6, 2013 at 9:55 am
    Brandon
    You will get a better answer at Adobe After Effects Expressions.
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    2011 3D Demo Reel:
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Xavier Gomez
    February 6, 2013 at 1:36 pm
    Assuming that :
    1- your script has already identified the layer (let’s call it theLayer),
    2- your script has a string variable (called say expr) that contains the expression text,
    you can go on like this:
    var prop = theLayer.transform.position;
    prop.expression = expr;
    prop.expressionEnabled = true;
    if you want need your script to read the property’s values at a given time t, it is like this:
    – for pre-expression value: prop.valueAtTime(t, true)
    – for post-expression value : prop.valueAtTime(t, false)
  • Brandon Smith
    February 6, 2013 at 5:42 pm
    Thanks for the response Xavier
    Here is my code that I am currently working with, but it keeps crapping out when it gets to the actual expression. Any ideas?
    var myComp = app.project.activeItem;
    var myLayer = myComp.selectedLayers[0];
    var prop = myLayer.transform.position;
    prop.expression = "loopOut("cycle")";
